Re: c113 or c119 engine
Posted by Del Jarman on December 31, 2007 at 19:31:48 from (172.131.55.198):
In Reply to: c113 or c119 engine posted by MattMalcome1 on December 31, 2007 at 18:39:15:
I think you will find the c113 will fit the Farmall A, B or C with no hydraulics. Double check the ring gear as you may have to use the one from the tractor.
