Re: Ignition: 6v to 12V
Posted by Fancy Farm on January 01, 2008 at 06:54:40 from (208.66.245.158):
In Reply to: Ignition: 6v to 12V posted by L.C.Gray on December 31, 2007 at 16:13:28:
Go to NAPA and get a 12V internally resisted coil and put it on and don't worry about voltage to distributor. You can get the coil for less than $20.
