Ignition: 6v to 12V
Posted by L.C.Gray on December 31, 2007 at 16:13:28 from (208.193.186.28):
I'm getting close to start up on the new engine in my 47 I-4 Road Roller Conversion. What little wiring was there was totally weathered away so I'll be rewiring it from scratch. I'm going to run it on 12 volts negative ground using the original starter. I plan to try to replace the original 6V generator with a similar 12V later. I also have replaced the H4 magneto with a IH distributor, drive and coil setup. Will the distributor, namely the condensor, and the coil handle 12 volts, or will they have to be upgraded?
Part of me wants to keep it 6v, but 12v is just easier in this day and age.
