If it is going to freeze for the first time this season then you don't live in Chicago. There is a difference between freezing air temperature and cold enough temperature to freeze the water in the tires. They are insulated by the rubber and are sitting on warm ground. If you are talking 25 degrees or higher for a few hours the water won't freeze, or at least won't freeze enough to cause damage.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
