Posted by justin14054 on January 01, 2008 at 07:40:54 from (24.11.73.35):
In Reply to: Ignition: 6v to 12V posted by L.C.Gray on December 31, 2007 at 16:13:28:
I have no problem with any 6volt systems.The key is large battery cables (Thickness). As for conversion you can get a resistor at TCS for $5 .Run 12v battery and drop across resistor to distributer -As for other comments 12 volt verse 6volt coil= I learned the hard way on a 8n.Bought new front mount 12 coil ran 12 volt to it and smokesd it(Split in 1/2) needed a resistor in line even though it is 12 volt coil Just my $.02 worth justin
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
