Geez, I can't make any suggestions on here the last few days with out everone jumping all over me. The machine shops around here have a special flywheel grinder machine. It mounts the flywheel on the crank mounting surface so it grinds tru. It is used because of the heat caused hard spots that will cause a lathe to chatter. You can only grind so much from a flywheel before it is a doorstop. Thats why when they are ground they do not remove all the cracks or hard spots, not required. I'am just stating as I see it, I have never seen a tractor flywheel turned on a lathe so if you must batter away on me I can take it and will not go away for stating my opinion!
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
