I agree with you MN Scott.I've had hundreds of flywheels resurfaced both ways durring my years of mechanicing, and a flywheel that has been resurfaced by grinding has a far superior surface than one that has been turned on a lathe.In fack HY-Capacity put out an official statment from their factory that their clutch discs are not to be used with a flywheel that has been resurfaced on a lathe. The only down side about grinding is a stone will not make a square corner.The stone leaves a radius that the pressure plate backing plate will not set completely down on the machined surface.That problem can be overcome by grinding a bevel on the outside bottom edge of the backing plate.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
