Re: M water pump--sealed ball bearings?
Posted by Roger46 on January 01, 2008 at 17:10:42 from (69.58.143.235):
In Reply to: M water pump--sealed ball bearings? posted by zooeyhall on December 31, 2007 at 12:10:53:
You still have to grease the water pump even if you replace the ball bearings with sealed ones. The second grease fitting greases the internal sleeve bearing on the water pump drive shaft. That is the one that gets grease all over your fan anyway and is important to grease. The ball bearings support the fan and take the fan belt load and are external to coolant. Roger
