Re: super H no charge
Posted by Janicholson on January 02, 2008 at 15:38:24 from (66.173.50.38):
In Reply to: super H no charge posted by jm on January 02, 2008 at 15:25:51:
Simple test.
Start the tractor and run at 1/2 throttle.
Use a jumper wire or test lead to ground the small "F" terminal on the generator. Go to a good ground. If it now shows a good charge, the regulator probably needs to be replaced (or points cleaned in it with 240 paper). If it does not I suggest using John T's charging System diagnosis procedure. Use the search for box and put in John T charging system. JimN
