The set up on the tractor works and I have seen it duplicated on many more. The tractor can be steered with a couple of fingers.
The valve probably has a restriction on the port that goes to the Behlen. I believe you are right about the spring loaded relief on that circuit. It limits PS energy to about 1000 lbs. Not sure if the denied oil goes to the reservoir or to the inlet of the Liftall. Your set up will also work but the one old valve will do the job of both of your valves. It will be alot cheaper as well.
There is something that has not been mentioned. The aftermarket Behlens are different than the units purchased by IH for the 400-450. The input shaft is several inches longer and is machined for the steering wheel. A welder can fix that 'short coming'.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
