Re: 1680 Combine
Posted by Tom Bateson on January 02, 2008 at 18:26:34 from (12.66.103.187):
In Reply to: Re: 1680 Combine posted by IaGary on January 02, 2008 at 16:52:29:
Yes, it is the tray under the set of five augers. The two outside and center augers have wore thru the metal tray. I had considered installing sheet metal but getting to the center auger area is going to be extremely difficult. I am also concerned about a fire when welding inside the combine. Considered using pop riviets to retain the repair panels. I would still need to replace the front wood block bearings inside the machine as well as repair / replace the augers. Have you ever welded new tubing to the end of the augers that would ride in the wood blocks.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
