Re: 1680 Combine
Posted by C-man on January 02, 2008 at 19:49:48 from (208.34.15.20):
In Reply to: Re: 1680 Combine posted by Tom Bateson on January 02, 2008 at 18:26:34:
We replaced the wood blocks with a bearing kit that the Case-IH dealership has. If I remember right, there was a small shaft that went INSIDE in auger shaft. Not 100% sure though. It has been several years ago. This was the first year we had to replace a bearing, while we replaced the wood blocks every couple years. The kit was more expensive. We made our own wood blocks. Even put grease zerks in one set, didn't seem to help much. I don't know if the augers run to fast to wear out the wood.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
