Re: Cub Cadet problems
Posted by Janicholson on January 02, 2008 at 18:53:33 from (66.173.50.168):
In Reply to: Cub Cadet problems posted by ed in cny on January 02, 2008 at 18:43:05:
If the push button is stuck down and the Pawl stays out of the slots, I would take off the rubber handle and heat the lever with a propane torch. Then tapping on the button, and tapping up on the pawl,should begin to loosen it. It may take repeated heatings and maybe a bit of auto trans fluid to free it up. They can get bent. Then the whole lever needs to come off to be repaired. If the blower has assist springs, make sure they are working and adjusted. JimN
