Re: HYDROLIC PUMP BETWEEN DISTRIBUTER AND ENGINE
Posted by Allan In NE on January 03, 2008 at 04:32:54 from (148.78.243.24):
In Reply to: HYDROLIC PUMP BETWEEN DISTRIBUTER AND ENGINE posted by SD FARMALL on January 02, 2008 at 18:24:47:
What you are really asking, is if you have a low pressure or high pressure pump.
I've never seen one, but from your pictures, the configuration appears that your pump is a M&W low pressure power steering pump.
Word on the street is that you don't need the priority valve. Dunno, like I say, I've never seen one.
Your "cylinder" is called a torque generator or torque motor, which appears as if it came off of a John Deere. If you're putting it on an M, you'll need the proper guage panel plate to properly mount it.
Also, it has both "in" and an "out" ports. Get the flow right and hook 'er up. Should work.
If the engine sounds like it is "laboring" and/or the steering "locks up", chances are the pump is a higher pressure pump and you'll need the priority valve.
Don't think so tho.
Allan
third party image
third party image
third party image
third party image
