Re: HYDROLIC PUMP BETWEEN DISTRIBUTER AND ENGINE
Posted by SD FARMALL on January 03, 2008 at 17:30:40 from (69.77.194.186):
In Reply to: Re: HYDROLIC PUMP BETWEEN DISTRIBUTER AND ENGINE posted by Allan In NE on January 03, 2008 at 04:32:54:
Alan,
Thanks for the help, and the pictures it is greatly appreciated, as for the plate I already have it, and mounted it on the tractor.
It is a 201p M&W, do you know what does the P stand for? I'm hoping Power Steering but that seems like it would be to easy!
Again Thanx much,
Eric
