Re: The pictures you asked about
Posted by gots-2-go on January 03, 2008 at 16:04:38 from (69.72.58.5):
In Reply to: Behlen Power Steering Pump Install on SMTA posted by Idaho Boy on January 02, 2008 at 11:17:15:
Here is the first picture of the Home Made Behlen Power Steering bracket that you asked about.
This one is from a different view of it.
It was made from 1/4" Thick by 1 1/4" Wide flat bar stock, and held together with two rivets.
If you think they are helpfull to your setup just save them to your PC and then you can enlarge them so you can see/read the measurments.
It was once installed on a Farmall M, but I am going to put the setup on a H.
If you want an orginal type Behlen bracket like Wardner's picture displayed you can post a wanted ad here, check with salavge places, or ebay, one show's up there every now and then.
Good Luck, you will enjoy being able to steer with one or two fingers once it's completed.
