Re: What the heck is this? Don't tell me a Farmall.
Posted by Harold H on January 04, 2008 at 05:11:56 from (69.40.30.122):
In Reply to: What the heck is this? Don't tell me a Farmall. posted by Brando on January 03, 2008 at 19:57:03:
Can't really see the brakes, but if it has disk it is a Super C, if it has bands it is a C. Also, it will drive better if you turn the front wheel around. The caster is supposed to be to the rear.
Harold H
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
