Re: What the heck is this? Don't tell me a Farmall.
Posted by Hugh MacKay on January 04, 2008 at 13:50:31 from (209.226.106.43):
In Reply to: Re: What the heck is this? Don't tell me a Farmall. posted by Nat 2 on January 04, 2008 at 12:36:00:
Nat: My 656 had a 12 volt generator, but then it was 67, the last year with the 06 grill. It was a spring of 67 tractor. Your probably right on last of 06's having alternators. The 140 had a generator until serial number 57723 sometime late 75.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
