Thanx for all the help and more info.
Posted by Brando on January 04, 2008 at 16:37:31 from (207.69.139.148):
In Reply to: What the heck is this? Don't tell me a Farmall. posted by Brando on January 03, 2008 at 19:57:03:
Yes I had a beer in hand. No I havn't taken it apart. It was a rental at some time and it is 12 volt (now). But the beer can was empty. No disk breaks and I can't read the plate on the tool box. Yes the hydraulic pump is about 1/2 inch below the gas tank. By the way what's wrong with holding a beer? Someone also bent the clutch arm to look like the supers. I am in Perris CA about 20 miles from Corona or Riverside or Lake Elsinore. Thank you all for the help I didn't expect anywhere near the amount of replies. Thanx,Brando
P.S. What do some of you guys have against beer?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
