Posted by Daniel Hindry on January 04, 2008 at 17:08:36 from (203.97.108.140):
In Reply to: Re: B275 stops running posted by Daniel Hindry on January 04, 2008 at 12:13:49:
I have taken the fuel injector pump regulator/governor apart, cleaned the smalls screen filter and checked all the parts, found that the little piston seemed to be very very tight inside the sleeve.
Here in New Zealand Diesel fuel has had something removed from it recently, might be sulfur? From what I have found it was used as a lubricant.
I am going to go to the shops and see if I can find an additive to add to the fuel.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
