i woud try and set the main jet 3 to 3 1/2 turns out, idle jet about 1-1/2 turns out. try and remove the air cleaner pipe from the carb throat while you are trying to get it to start. if you have a major flooding problem,you will see the fuel drip out. i am gonna guess its a letter series farmall, with the magneto.did you by chance change the spark plug wires? if so are they copper core and not the carbon fiber wires? mags dont care for them. also whick plugs are you using? if its an autolite 386, pretty sure its a resistor plug. try autolite 3116 plugs. like allan said them old i-h's dont like a lot of choke. pull the lugs and see if they are wet. if so clean em up and re-install. then with the choke off, throttle maybe 1/2 open give er a try. you can also try a quick shot of ether in the carb to see if she'll start.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
