Re: IH 986 compatible with 1066
Posted by mkirsch on January 05, 2008 at 16:48:09 from (72.226.216.69):
In Reply to: IH 986 compatible with 1066 posted by dave guest on January 05, 2008 at 08:05:47:
The bolt pattern from engine to bell housing is the same.
However, everything on top is different from one to the other. The steering column, instrument cluster, operator's platform, etc. are very different.
Your path of least resistance will be an engine swap. Just take the good engine and put it in the tractor with the good transmission. It'll bolt right up like nobody's business, and you won't have to futz with trying to figure out which parts need to be changed.
