Posted by richardinnz on January 05, 2008 at 18:57:16 from (125.239.164.56):
In Reply to: IH 574 flywheel posted by Lawrence Greveling on January 05, 2008 at 16:33:36:
When you are refacing, don't forget to take off the same amount from where the flywheel to crankshaft bolts go in, the clutch plate hub will foul the bolt heads when it gets part worn.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
