Posted by John A. on January 05, 2008 at 23:14:59 from (138.210.117.122):
In Reply to: Seized M posted by Smoothcat on January 05, 2008 at 20:33:54:
Smoothcat, You can do this quicker and easier than waiting 6 months for the tranny fluid to free it up. Follow what I telly you. 1st, get hood, gas tank, head, manifold, and oilpan off. 2nd, Remove the rod caps, # them and set aside. 3rd, Roll tractor outside, and remove ALL combustables away from the tractor and immediate area. 4th, One cylinder at a time, fill the cylinder full of Diesel, add a splash of gas. Set it on fire, let it burn itself out! 5th, drive the pistons up for the crank is in the way to go down. NOTE( if the engine was on an engine stand and the Crank was removed, one could drive the pistons out, and down through the bottom) Thus saving the pistons and sleeves, they might be saved. The fire will expand the sleeve and break the rust loose. Just be safe, observe common safty practices. You can get this job done in a afternoon. Sometimes two or more burns may be needed if the piston is near the top of its stroke. Good luck, hope this helps. Later, John A.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
