Re: magneto or distributer
Posted by El Toro on January 06, 2008 at 08:44:42 from (64.12.116.73):
In Reply to: magneto or distributer posted by Pat-CT on January 06, 2008 at 08:30:45:
You need battery voltage for a distributor that's fed from an ignition switch to the ignition coil and then to the points.
A magneto does not need battery voltage since the magnets in the mag creates the hot spark when they pass by the coil. Mags don't need a fully charged battery if you can hand crank the tractor.
Hal
