Looking at it where the spark plug wires are attached a distributor will have the center wire in the cap going to a separate round coil that is about 1/2 the length, and the same diameter as a ketchup squirt bottle. It may have a flange rib around it and be clamped in a metal bracket. The Mag will be a contained unit with the center wire going to a built in greyish black top on the unit. The mag will make spark with all wires disconnected from it, and never gets any power from the electrical system. (It makes its own) The distributor system might also be a Delco after market replacement that has a right angle drive with the cap pointing upward. (no mag looks like that) Some mags have been converted to be used as a coil system (and work OK) they have a coil as described above, and the unused built in coil on the top of the Mag. All coil systems need power through an ignition switch. All mags are grounded to stop with a similar looking, but very different switch. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
