Re: Rear Ballace for front loader
Posted by old on January 06, 2008 at 20:39:44 from (4.244.222.42):
In Reply to: Rear Ballace for front loader posted by Jeef on January 06, 2008 at 20:01:24:
What I do is this. I put a back blade on and then load the blade down with suit case weights. Doing that puts the weigh way out back and it does make a big difference. My tires are also full of fluid. My tractor with the loader can pick up 2500lbs easy and even with 6-85lbs weights on the blade and the tires full of fluid I can have problems at times
