Rear Ballace for front loader
Posted by Jeef on January 06, 2008 at 20:01:24 from (69.252.230.76):
I have a 574 that has a rather robust front end loader that will lift the rear of the tractor off the ground easy. I need to ballance it out. My old tractor used a box blade to ballance the weight out but I know that will not be near enough for this setup. I figure the loader should be capable of lifting 1500 lbs minimum, does that mean I need 1500 lb of weight on the rear?
Also I noticed the loader lifts up much easier on the right rear than left. Wondering if there is less fluid in one tire than the other.
