Re: international.i-4 shift pattern
Posted by Wardner on January 06, 2008 at 22:04:18 from (4.154.241.63):
In Reply to: Re: international.i-4 shift pattern posted by dennis van popering on January 06, 2008 at 21:35:36:
I am not saying that at all. The speeds are progressive. Each gear has a higher speed than the next starting with 1st and ending with 5th.
When I speak of ratios, I am using your antecedent regarding the comparison of an I-4 to a H. Industrials use different ratios from the Farmalls.
I doubt if it is possible to engineer the reversal of the 2nd-3rd slider and the reciprocal countershaft gears. But even if it was, the 1st/2nd shift and the 3rd/4th shift would be very difficult.
Isn't the shift pattern cast into the rear frame lid?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
