Jeef: The back blade with weights is quite effective. They can also make the blade cut better when using it. The down side is length if your working in tight quarters.
For that I used a 55 gallon barrel filled with concrete and fitted with steel cast right into the concrete for picking it up with 3 point hitch.
Bottom line is you still need the tires loaded plus the counter weight, for any serious loader work.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
