Re: Rear Ballace for front loader
Posted by rich4 on January 07, 2008 at 10:18:14 from (74.60.110.90):
In Reply to: Rear Ballace for front loader posted by Jeef on January 06, 2008 at 20:01:24:
Might want to check fluid level in rear tires, also lift anything heavy on level ground only. Those rear tires should be able to hold a lot of fluid, that keeps the weight low, also a counter weight of several hundred pounds on the rear would help. I believe counter weights help the front end loading more than tire weight. Another variable is how far the loader sticks out in front of the tractor. The farther it is out front the more counter weight you may need. The guy with the barrel of concrete has an idea, but a full barrel may be way too much to move around, maybe a half barrel.Could use a whole barrel, fill halfway and fill with rocks if you need more weight.
