I have seen the bareel full of cement work. Also have seen then full of water, scrap iron, sand, dirt anything that is heavy. A couple of them had regular 3 point style drawbars stuck in the barrel and a bracket for the top link so ity doesn"t sway for the hook up. I tend to like the sand idea so the weight can be adjusted and I always have use for sand once in a while. Only thing is you might have to "weed " the barrel in summer and keep it in the shed or covered up so the barrel doesn"t rust out.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
