Re: Demagnitization Magneto
Posted by El Toro on January 07, 2008 at 14:35:53 from (205.188.116.73):
In Reply to: Demagnitization Magneto posted by Kristof on January 07, 2008 at 09:21:16:
Pull the coil wire from the cap and hold it near a good ground while someone cranks over the engine. Make sure the grounding switch is in the run postion too. I would worry more about the coil or condenser than the magnets being hit with battery voltage. Hal
