Re: cooling problems
Posted by Heat Houser on January 07, 2008 at 18:05:46 from (69.66.35.73):
In Reply to: Re: cooling problems posted by Heat Houser on January 07, 2008 at 18:02:29:
Forgot to add, could the bottom hose be "sucking" shut either externally or internally? The internal lining of the hose can seperate and suck shut.
