Re: F-14 CLUTCH PROBLEM
Posted by Andy Motteberg on January 07, 2008 at 21:57:34 from (4.143.219.131):
In Reply to: F-14 CLUTCH PROBLEM posted by 39 AND HOLDEN on January 07, 2008 at 21:03:16:
No need to split it, just remove the drive coupler shield, remove the joint parts, remove the overdrive (it can be a little tough to get out),remove the clutch pedal linkage and throttle arm, remove the clutch cover and you are in the clutch. You do NOT need to split the tractor. Good luck!
Andy.
