Dave: Liquid filled tires probably give more benefit on a loader tractor than any other situation, with tractors hauling heavy loads on hard roads a close second.
Calcium chloride is your best option, yes it requires a bit of maintinence, mere pennies when you consider the benefit. There are a few rules with calcium chloride in tires. Never leave small leaks, fix them immediately. Fix flats immediately, and wash the rim thouroughly. About every 5-7 years change the center housing of the valve stem. It is the only metal making contact with the calcium chloride. Fix it before it leaks. Just jack the tractor with valve stem at top, remove the stem and replace it with a new one. You will need air on hand, to replace lost air.
I've seen lots of rims last 40-50 years, tires filled with chloride the whole time. One other thing, on a loader your still going to miss your counter weight.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
