Re: 450 hdy?
Posted by Wardner on January 08, 2008 at 15:26:53 from (4.154.241.37):
In Reply to: Re: 450 hdy? posted by Janicholson on January 08, 2008 at 14:58:56:
I use the little spring loaded ball plug for priming as well.
I never understood why some people pressurize the reservoir. Theoretically, that procedure should not work as both ports would get pressure on a open center system. That situation would cancel flow through the pump. If one of the work valve levers was moved off center, it might work but why go to the trouble of setting up the air hose.
