Posted by Janicholson on January 08, 2008 at 17:25:29 from (66.173.50.77):
In Reply to: Re: 450 hdy? posted by Wardner on January 08, 2008 at 15:26:53:
I have used it, and had it succeed. The principle is that if 35psi is put in the res, the bubbles will be about 35 to 40% of their size at atmospheric pressure. This allows the bubbles to be swept up and moved within the system easier. The smaller bubbles also allow additional hydraulic fluid to pull in where they had been. It does work, not always, but it is not a mistake. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
