Farmall Tractors Discussion Board
Re: Govenor on Farmall A
Posted by C. Amick on December 14, 1998 at 10:08:45:
In Reply to: Govenor on Farmall A posted by G. Trible on December 12, 1998 at 06:30:36:
Did you check the shaft bearing when you had the governor off. It is a doughnut shaped bearing about the size of a quarter. It is located on the shaft that comes into the governor from the engine, not on the throttle shaft.
Post a Followup
: Re: Re: Govenor on Farmall A
