Re: Farmall M hand crank Shaft
Posted by Nebraska Cowman on January 09, 2008 at 04:56:49 from (65.162.146.41):
In Reply to: Farmall M hand crank Shaft posted by Zach Bouchard on January 08, 2008 at 19:21:50:
There is a collar on the rear piece behind the spring. Under the collar is a pin the holds the two pieces together. Then the shaft will slide ahead enough to let the ratchet out. Then I don't know or remember if there is enough room for the shaft to go out the back. I've never taken one apart with the bolster still on the tractor.
