Re: H block damaged while removing sleeve.
Posted by Spook on January 09, 2008 at 06:06:30 from (68.73.206.14):
In Reply to: Re: H block damaged while removing sleeve. posted by Allan In NE on January 08, 2008 at 17:19:38:
On our prints that is Distance "Z" or the ride area. That is where the diameter is gaged, roundness and surface finish is determined. The space below that is just clearance.
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
