Re: 1944 M Timing Gears
Posted by Janicholson on January 09, 2008 at 16:50:56 from (66.173.50.78):
In Reply to: 1944 M Timing Gears posted by Matt Demuth on January 09, 2008 at 16:32:22:
The only thing I could recommend is to rotate the engine through several cycles with the plugs out and watch the gears and the distributor shaft. The distributor shaft is a two part item with the centrifugal advance and springs in the middle. If it all rotates, and all valves move, I would put it together. I believe the compression (though not what you would like on one cylinder) is the telling that the drive gears are in and functioning. Check the part number on the cam gear and see if it has been updated to the later stronger gear from a SM, or 1951&1/2 late M. If not I would do it now. JimN
