Posted by Matt Demuth on January 09, 2008 at 16:32:22 from (216.114.222.46):
I posted to the forum about a month ago because my M would not start after I screwed up the hydraulic lines. I received a great amount of very helpful information (Thanks to everyone that reply"d) but alas it still would not start. Out of desperation I took the front end off and removed the timing gear cover. Everything looks good. The main gear is not loose and the keyway lines up with the keyway for the crank pulley. The timing marks are lined up. The cam gear is solid. Is there anything I am over looking? Any thing I can test before I put everything back together? I would hate to put it all back together and then find out I over looked something. By the way, I did check compression before taking it apart and 3 cylinders were in the 90 to 95 pound range and 1 was at 55. Any additional advise would be appreciated. Thanks, Matt
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
