Re: 1944 M Timing Gears
Posted by Janicholson on January 09, 2008 at 17:30:41 from (66.173.50.78):
In Reply to: Re: 1944 M Timing Gears posted by John M Seasly on January 09, 2008 at 17:13:33:
John, with respect, the 44 H may have been a dual fuel engine with a PSI of less than 90 new. Engines with even 50 PSI compression pressure will run, all they need is to draw fuel into the cylinder, and burn it well enough to spin the crank. Some single cylinder engines have compression less than 50 PSI. The issue with this engine is (opinion) not compression (or even valve timing), but either spark timing, or fuel intake related. JimN
