Re: 1944 M Timing Gears
Posted by John M Seasly on January 09, 2008 at 17:13:33 from (67.174.31.57):
In Reply to: 1944 M Timing Gears posted by Matt Demuth on January 09, 2008 at 16:32:22:
You shouldn't have more then a 10% between cylinders, also with compression of less then 100 I was taught it won't start. On the cylinder that has the low compression; squirt a little oil into the cylinder and recheck the compression. If it goes up it is bad rings; if it remains the same valves.
