450 HYD.
Posted by Hoss357 on January 10, 2008 at 04:22:24 from (24.176.33.82):
what would make the hyd build pressure..i went home squirted some hyd oil in the plug of the pump..started tractor work levers a little...walked away and let it run a couple min. i came back oil coming out of the top of resv.... a line wasn't tight and so on..tightened line oil stopped coming out..p/s and loader started working a little thought maybe something gave and it was low on oil...pulled the dip stick and got a shower of oil..let it sit a while and started over didn't do it again but loader and p/s havn't started working again either????
