Farmall 400G Coolant Leak
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Larry(SD) on February 26, 2000 at 16:19:20 from (208.164.249.225):
I just noticed that coolant is dripping from the front of the radiator fan when tractor is off. Could the source be the water pump? If so, how big of deal is it to replace the water pump? Are there any precautions I should take?
Thanks in advance.
Larry
Post A Followup
: Re: Farmall 400G Coolant Leak
