Posted by Owen Aaland on January 10, 2008 at 16:34:14 from (65.165.246.131):
In Reply to: 706 plugs posted by rustin on January 09, 2008 at 20:27:22:
The D16 plug number was replaced D15Y about 40 years ago. They are one heat range colder but have an extended tip to get the spark farther in the compression chamber. D18Y was recommended for light duty. When leaded gasoline was no longer available the recommended plug was changed to D18Y for regular service and D21 for light duty. Do not use D21 plugs if you are going to be using the tractor for heavy use. The will be too hot and can lead to engine damage from preignition.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
