Re: Farmall H Hyrdraulics
Posted by Allan In NE on January 10, 2008 at 18:12:02 from (148.78.243.24):
In Reply to: Farmall H Hyrdraulics posted by TimWafer on January 10, 2008 at 17:49:31:
Tim,
The breakpoint is 34xxxx so you're okay and don't have to change that front end.
Looks like an IH pump. I'd get the proper manifold.
Just pull the belly pump drive coupler out of the bottom. You don't have to take that old pump out of the tractor.
Use the reservoir’s drain as your live pump input and plumb in a tee to the fill for your dump.
'Bout all you need is a couple of gaskets and a valve arrangement for your load circuits.
Allan
