Re: F-20 VALVE AND PISTON FYI
Posted by Kevin LA-CA on January 10, 2008 at 18:51:59 from (72.67.232.190):
In Reply to: F-20 VALVE AND PISTON FYI posted by BIG BORE 20 on January 09, 2008 at 19:37:33:
Ron - I think this is true only if you have the Regular with the 3 7/8" (?). The F-20 with 4" bore has enough clearance for the crank end of the rod.
.. but I have only worked on the Regular engine.
kevin
